aminhas
Unbend
         how to unbend this part any one guide.
kind regard,
Hello!
It is necessary to do a little differently.
See the attached file.
@ I'm sorry for my english
12 REPLIES 12
repeat making your part using extrude and extrude but use the sheetmetal template.
Then use Sketched Rip feature, and unfold/flat pattern will work.
aminhas
(To:TomD.inPDX)
I can't did you work on file than I will able to see?
I did convert your file and it did work.  The thickness has to be consistent and you must create a rip feature to make it unfold.  If you start with a sheetmetal part, it will work fine.
Hello!
aminhas
(To:SergeyGvozd)
thank you!
aminhas
(To:SergeyGvozd)
cup.tifHello,
          if the part is in Cup shaped than how to unbend?
cup.tif
Hello.
aminhas
(To:SergeyGvozd)
          my require wall thickness is .15mm on this flat pattern not work any other option?
Kind regards,
Hello!
Learn more help
aminhas
(To:SergeyGvozd)
         can we make blank punch and draw die of said part?
Kind regards,
I am sorry.
I have never engaged in designing stamps.
dschenken
(To:aminhas)
A cup cannot be unbent because it requires material to be stretched to form it. The flat pattern ability in Creo requires that parts be be made of parts with tangent areas of uniform curvature.
