Unfold Part that has Offset Lip
mmaenpaa
Is this a known issue?
When using Unfold Part, the Offset Lip does not unfold.
See attached pictures.
Mike
8 REPLIES 8
How did you model this offset lip ? Usually when I design something like this it unfolds.
mmaenpaa
(To:RaphMORIN)
Hi Raphaël,
I didn't do anything fancy, this was just a test part I made after a co-worker with a more complex part pointed out the problem.
It's just a flat face, then I added a lip, then used the Offset tool.
Mike
Creo Direct Elements 18.1
mmaenpaa
(To:mmaenpaa)
I didn't see a way to upload a file here, so I posted it at Unfold Part that has Offset Lip - CoCreate User Forum
Mike
Oups, I didn't see you are working on Creo direct, I thought it was on Creo Parametric. Sorry can't help you.
Yes, it's a bit difficult to find.
Like so much in this forum
You have to use the advanced editor for the attachment of a file.
I have the German setting, but the buttons would be at the same place
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct /Drafting, /Modeling and /Modeling Express 8.0 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
Thanks FriedhelmK.
I looked in the advanced editor originally but didn't see that it was in the bottom right in a faded font color.
It should be with all of the other editor tools.
Have you had a problem like I had with Unfold Part?
Mike
Offsets cannot be unfolded.  I am not sure about previous versions, but V19 actually will generate an error message "Offsets can not be unfolded."
Creo Element\Direct Modeling 20.6.0.0.0
Thanks for checking Tom.
V18.1 doesn't give the error message.
It works when using Unfold 2D and sending to a workplane or to Drafting, wonder why it wouldn't be able to do it with Unfold Part.
Mike
