Unhide command
renano
2-Explorer
Unhide command
i opened an assembly model with some of its components hidden but when i did the unhide for these and then saved/filed the assembly, closed it and then opened the same assembly model, these components remained unhidden
1 REPLY 1
Reynaldo,
After unhiding the components, it is necessary to save the status, before saving the assembly.  Otherwise, they will remain hidden, the next time you retrieve the assembly.
After unhiding the components, go to View > Visibility > Save Status and then save the assembly.
Amit
