Is there a way to change the unit of measure for an already existing harness part?
(right click on the harness part in the model tree, info - model, shows current unit of measure...)
Is it a paramater that was added to the models? If I right click on my model, edit parameters, there is a parameter that is UM (unit of measure) - that I can edit.
Thanks, Dale
you can change it from HARN SETUP menu
