Update part with drawing
ptc-5346227
In Proe WF5, I have drawn a part model and a drawing for the same.
I took a back up and renamed both.
But when i open the drawing it is asking for the part with the old name.
What should i do?
1 REPLY 1
You should learn the ackward method that Pro|E manages parent/child relations and how stored memory is critical to successful actions.
In your case, you can only do this one way. Although the interface is updated, and a few options are added, knowing the basics is relevant:
To rename a drawing an model (in the case you want a copy of both).
First copy the drawing and part file to a temporary folder
Make this temporary folder the active folder.
Erase all files in memory.
Open the drawing file
Open the part file
Rename the part file, all versions on disk (it will only rename the one that is in the temp folder)
Rename the drawing file
Now save both and close the files.
Use the Windows file manager to move the files where they belong.
Change the working folder back to where you were.
I am not familiar enough with WF5 to know what updates have been made. Today there is a more dynamic UI and a config setting that allows drawings to be copied. Regardless, I highly recommend understanding the basics first. I still cannot grasp the new UI and I still fall back to the old way of doing things.
Other forum members will shime in here to clarify the other options.
