I have used the Z-radius for the first time but find that I am unable to select the center of the radius in order to dimension it from an x and y locations?
Hi William,
Please take a look at the following article for information on how to create a z-radius dimension:
If you don't have a user name and password for PTC Support, you can create one here.
Amit
Hello Amit,
I know this post is three years old but I have the same problem as William and I don't feel you answer is complete. The OP's problem as well as mine is the need to dimension the center point of the Z-Radius in X and Y after the Z-radius has been created and placed on the drawing. The instructions in your link only show us how to create the Z-radius.
Is there more to the instructions or do you of a way to dimension to the center point of the radius in X and Y not just the radius?
It can be done as seen in the attached image with one dimension added and attached to Z-radius center point. Unfortunately, I did not create this drawing and do not know how to create the other dimension.
Jason
Creo3 M180
