Using Simulinks
hamid-shad
Using Simulinks
when I want to use SimMechanics Links and export my assembly to Matlab I face this error:
some constarints could not be translated into equivalent SimMechanics joints.
The Physical Modeling XML file has been saved as : SimMechanics models that you generate from this XML file
will be valid but will not represent your original assembly...
and in Matlab I face this error:
Warning: The CAD exporter could not map a set constraints to a joint and hence the
weld joint arm/Weld1 has been added in its place.
what shoud I do now?
Best Regards
will be glad to recieve E-mails from you if you got answer:
