VARIABLE DIMENSION
WilliamPatterso
VARIABLE DIMENSION
I have a tabulated drawing with a family of simular parts. I want a liniar dimension labeled "L" how can I over wright the numerical value with a lable the corrisponds to the value in the table?
William, First of all, rename the dimension from the default name (such as d12) to L. Then, in the drawing, access the dimension properties by double-clicking the dimension. Edit the dimension text from @D to @S. The dimension will display symbolically rather than numerically, showing the symbol L. You can automate a table for a family of parts. The part would have to have a family table in the 3d model to vary the dimension L. Then in the drawing, set up a table with a repeat region (of 2D type, not the simple type) That will allow you to display in the table the range of values of L and the names of the associated parts.
