Hello.
I would like to change the active sheet on a drawing using VBA-API, but I can't find any way to do it, I'm new to VBA-API. The best I cold manage was to use macro to change sheets, which worked, but did produce somr undesired effect.
The documentation states "You can regenerate a sheet only if it is displayed.", so it must be possible to change the displayed sheet.
My code so far
Public Sub change_sheet_parameter()
Dim conn As IpfcAsyncConnection
Dim cAC As CCpfcAsyncConnection
Dim session As IpfcBaseSession
Dim model1 As IpfcModel
Dim sheetData As IpfcSheetData
Dim sheetowner As IpfcSheetOwner
Dim sheetInfo As IpfcSheetInfo
Set cAC = New CCpfcAsyncConnection
Set conn = cAC.Connect("", "", ".", 5)
Set session = conn.session
Dim oModelDescriptorCreate As New CCpfcModelDescriptor
Dim oModelDescriptor As IpfcModelDescriptor
name_w = "SHM-7457-004.drw" 'Name of the drawing
Set oModelDescriptor = oModelDescriptorCreate.Create(EpfcMDL_DRAWING, name_w, Null)
Set model1 = session.RetrieveModel(oModelDescriptor)
Set sheetowner = model1
Dim oWindow As pfcls.IpfcWindow
Set oWindow = session.OpenFile(oModelDescriptor)
oWindow.Activate
Set sheetInfo = sheetowner.GetSheetInfo(1)
test_ = sheetInfo.Height
MsgBox test_
'The part where I would like to change the displayed sheet.
sheetowner.RegenerateSheet (1)
End Sub
So the answer was in the tutorials for VBAPI in the pfcDrawingExample.vb
In the "Create drawing views" example it clearly shows what command to use.
'Create drawing views
'Function : createSheetAndViews
'Purpose : This function adds a new sheet to a drawing and
' creates three views of input model.
Public Sub createSheetAndViews(ByRef session As IpfcBaseSession, ByVal solidName As String)
Dim model As IpfcModel
Dim solidModel As IpfcModel
Dim drawing As IpfcDrawing
Dim sheetNo As Integer
Dim modelDesc As IpfcModelDescriptor
Dim matrix As CpfcMatrix3D
Dim i, j As Integer
Dim transF As IpfcTransform3D
Dim pointLoc As IpfcPoint3D
Dim genViewInstructions As IpfcGeneralViewCreateInstructions
Dim proViewInstructions As IpfcProjectionViewCreateInstructions
Dim view2D As IpfcView2D
Dim outline As CpfcOutline3D
Try
'Get current model and check that it is a drawing
model = session.CurrentModel
If model Is Nothing Then
Throw New Exception("Model not present")
End If
If Not model.Type = EpfcModelType.EpfcMDL_DRAWING Then
Throw New Exception("Model is not drawing")
End If
drawing = CType(model, IpfcDrawing)
'Add new sheet to drawing
sheetNo = drawing.AddSheet()
drawing.CurrentSheetNumber = sheetNo
'Find the model in session or retrieve from disk
modelDesc = (New CCpfcModelDescriptor).CreateFromFileName(solidName)
solidModel = session.GetModelFromDescr(modelDesc)
If solidModel Is Nothing Then
solidModel = session.RetrieveModel(modelDesc)
Throw New Exception("Unable to load Model " + solidName)
End If
End If
'Add the model to drawing
Try
drawing.AddModel(solidModel)
Catch ex As Exception
Throw New Exception("Unable to add Model " + solidName + " to drawing")
End Try
'Create a general view from the Z axis direction at a predefined
'Location
matrix = New CpfcMatrix3D
For i = 0 To 3
For j = 0 To 3
If i = j Then
matrix.Set(i, j, 1.0)
Else
matrix.Set(i, j, 0.0)
End If
Next
Next
transF = (New CCpfcTransform3D).Create(matrix)
pointLoc = New CpfcPoint3D
pointLoc.Set(0, 200.0)
pointLoc.Set(1, 600.0)
pointLoc.Set(2, 0.0)
genViewInstructions = (New CCpfcGeneralViewCreateInstructions). _
Create(solidModel, sheetNo, pointLoc, transF)
view2D = drawing.CreateView(genViewInstructions)
'Get the position and size of the new view
outline = view2D.Outline
'Create a projected view to the right of the general view
pointLoc.Set(0, outline.Item(1).Item(0) + (outline.Item(1).Item(0) _
- outline.Item(0).Item(0)))
pointLoc.Set(1, (outline.Item(0).Item(1) + outline.Item(1).Item(1)) / 2)
proViewInstructions = (New CCpfcProjectionViewCreateInstructions). _
Create(view2D, pointLoc)
drawing.CreateView(proViewInstructions)
'Create a projected view bellow the general view
pointLoc.Set(0, (outline.Item(0).Item(0) + outline.Item(1).Item(0)) / 2)
pointLoc.Set(1, outline.Item(0).Item(1) - (outline.Item(1).Item(1) _
- outline.Item(0).Item(1)))
drawing.Regenerate()
MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
End Try
End Sub
Dim i, j As Integer
Try
End If
End If
End If
End If
Try
End Try
'Location
For i = 0 To 3
For j = 0 To 3
If i = j Then
Else
End If
Next
Next
End Try
End Sub
