VBA-API change active sheet
mvitárius
 Hello.
I would like to change the active sheet on a drawing using VBA-API, but I can't find any way to do it, I'm new to VBA-API. The best I cold manage was to use macro to change sheets, which worked, but did produce somr undesired effect.
The documentation states "You can regenerate a sheet only if it is displayed.", so it must be possible to change  the displayed sheet.
My code so far
Public Sub change_sheet_parameter()
        Dim conn As IpfcAsyncConnection
        Dim cAC As CCpfcAsyncConnection
        Dim session As IpfcBaseSession
        Dim model1 As IpfcModel
        Dim sheetData As IpfcSheetData
        Dim sheetowner As IpfcSheetOwner
        Dim sheetInfo As IpfcSheetInfo
Set cAC = New CCpfcAsyncConnection
Set conn = cAC.Connect("", "", ".", 5)
Set session = conn.session
Dim oModelDescriptorCreate As New CCpfcModelDescriptor
Dim oModelDescriptor As IpfcModelDescriptor
name_w = "SHM-7457-004.drw" 'Name of the drawing
 Set oModelDescriptor = oModelDescriptorCreate.Create(EpfcMDL_DRAWING, name_w, Null)
 Set model1 = session.RetrieveModel(oModelDescriptor)
 Set sheetowner = model1
    Dim oWindow As pfcls.IpfcWindow
    Set oWindow = session.OpenFile(oModelDescriptor)
    oWindow.Activate
Set sheetInfo = sheetowner.GetSheetInfo(1)
test_ = sheetInfo.Height
MsgBox test_
'The part where I would like to change the displayed sheet.
sheetowner.RegenerateSheet (1)
End Sub
So the answer was in the tutorials for VBAPI in the pfcDrawingExample.vb
In the "Create drawing views" example it clearly shows what command to use.
    'Create drawing views
    'Function   :   createSheetAndViews
    'Purpose    :   This function adds a new sheet to a drawing and
    '               creates three views of input model.
    Public Sub createSheetAndViews(ByRef session As IpfcBaseSession, ByVal solidName As String)
        Dim model As IpfcModel
        Dim solidModel As IpfcModel
        Dim drawing As IpfcDrawing
        Dim sheetNo As Integer
        Dim modelDesc As IpfcModelDescriptor
        Dim matrix As CpfcMatrix3D
        Dim i, j As Integer
        Dim transF As IpfcTransform3D
        Dim pointLoc As IpfcPoint3D
        Dim genViewInstructions As IpfcGeneralViewCreateInstructions
        Dim proViewInstructions As IpfcProjectionViewCreateInstructions
        Dim view2D As IpfcView2D
        Dim outline As CpfcOutline3D
        Try
            'Get current model and check that it is a drawing
            model = session.CurrentModel
            If model Is Nothing Then
                Throw New Exception("Model not present")
            End If
            If Not model.Type = EpfcModelType.EpfcMDL_DRAWING Then
                Throw New Exception("Model is not drawing")
            End If
            drawing = CType(model, IpfcDrawing)
            'Add new sheet to drawing
            sheetNo = drawing.AddSheet()
            drawing.CurrentSheetNumber = sheetNo
            'Find the model in session or retrieve from disk
            modelDesc = (New CCpfcModelDescriptor).CreateFromFileName(solidName)
            solidModel = session.GetModelFromDescr(modelDesc)
            If solidModel Is Nothing Then
                solidModel = session.RetrieveModel(modelDesc)
                    Throw New Exception("Unable to load Model " + solidName)
                End If
            End If
            'Add the model to drawing
            Try
                drawing.AddModel(solidModel)
            Catch ex As Exception
                Throw New Exception("Unable to add Model " + solidName + " to drawing")
            End Try
            'Create a general view from the Z axis direction at a predefined
            'Location
            matrix = New CpfcMatrix3D
            For i = 0 To 3
                For j = 0 To 3
                    If i = j Then
                        matrix.Set(i, j, 1.0)
                    Else
                        matrix.Set(i, j, 0.0)
                    End If
                Next
            Next
            transF = (New CCpfcTransform3D).Create(matrix)
            pointLoc = New CpfcPoint3D
            pointLoc.Set(0, 200.0)
            pointLoc.Set(1, 600.0)
            pointLoc.Set(2, 0.0)
            genViewInstructions = (New CCpfcGeneralViewCreateInstructions). _
                                   Create(solidModel, sheetNo, pointLoc, transF)
            view2D = drawing.CreateView(genViewInstructions)
            'Get the position and size of the new view
            outline = view2D.Outline
            'Create a projected view to the right of the general view
            pointLoc.Set(0, outline.Item(1).Item(0) + (outline.Item(1).Item(0) _
                         - outline.Item(0).Item(0)))
            pointLoc.Set(1, (outline.Item(0).Item(1) + outline.Item(1).Item(1)) / 2)
            proViewInstructions = (New CCpfcProjectionViewCreateInstructions). _
                                   Create(view2D, pointLoc)
            drawing.CreateView(proViewInstructions)
            'Create a projected view bellow the general view
            pointLoc.Set(0, (outline.Item(0).Item(0) + outline.Item(1).Item(0)) / 2)
            pointLoc.Set(1, outline.Item(0).Item(1) - (outline.Item(1).Item(1) _
                                     - outline.Item(0).Item(1)))
            drawing.Regenerate()
            MsgBox(ex.Message.ToString + Chr(13) + ex.StackTrace.ToString)
        End Try
    End Sub
1 REPLY 1
        Dim i, j As Integer
        Try
            End If
            End If
                End If
            End If
            Try
            End Try
            'Location
            For i = 0 To 3
                For j = 0 To 3
                    If i = j Then
                    Else
                    End If
                Next
            Next
        End Try
    End Sub
