VBA-API change active sheet
ppandarkar-2
 Hello.
I would like to change the active sheet on a drawing using VBA-API, but I can't find any way to do it, I'm new to VBA-API. The best I cold manage was to use macro to change sheets, which worked, but did produce somr undesired effect.
The documentation states "You can regenerate a sheet only if it is displayed.", so it must be possible to change  the displayed sheet.
My code so far
Public Sub change_sheet_parameter()
        Dim conn As IpfcAsyncConnection
        Dim cAC As CCpfcAsyncConnection
        Dim session As IpfcBaseSession
        Dim model1 As IpfcModel
        Dim sheetData As IpfcSheetData
        Dim sheetowner As IpfcSheetOwner
        Dim sheetInfo As IpfcSheetInfo
Set cAC = New CCpfcAsyncConnection
Set conn = cAC.Connect("", "", ".", 5)
Set session = conn.session
Dim oModelDescriptorCreate As New CCpfcModelDescriptor
Dim oModelDescriptor As IpfcModelDescriptor
name_w = "SHM-7457-004.drw" 'Name of the drawing
 Set oModelDescriptor = oModelDescriptorCreate.Create(EpfcMDL_DRAWING, name_w, Null)
 Set model1 = session.RetrieveModel(oModelDescriptor)
 Set sheetowner = model1
    Dim oWindow As pfcls.IpfcWindow
    Set oWindow = session.OpenFile(oModelDescriptor)
    oWindow.Activate
Set sheetInfo = sheetowner.GetSheetInfo(1)
test_ = sheetInfo.Height
MsgBox test_
'The part where I would like to change the displayed sheet.
sheetowner.RegenerateSheet (1)
End Sub
BenLoosli
(To:ppandarkar-2)
The .x_b is the binary format of a .x_t file. My guess is that PTC is only licensing the text format and not the binary format so you will only get the .x_t files. The only difference would be in the size of the exported file.
The results when imported into another system should be the same.
