VBA - Constraint Offset
HamsterNL
18-Opal
Does anyone have an exampl on how the create an ALIGN OFFSET constraint in VBA (I am automating from MS Excel)
My code fails when I try to supply an Offset:
        Set asmItem = assemblyModelItemOwner.GetItemByName(EpfcModelItemType.EpfcITEM_SURFACE, assemblyDatums(i))
        Set compItem = componentModelItemOwner.GetItemByName(EpfcModelItemType.EpfcITEM_SURFACE, componentDatums(i))
        Set ids = New Cintseq
        Dim OCMAssembly As New CMpfcAssembly
        Set path = OCMAssembly.CreateComponentPath(assembly, ids)
        Dim oCMSelect As New CMpfcSelect
        Set asmSelect = oCMSelect.CreateModelItemSelection(asmItem, path)
        Set compSelect = oCMSelect.CreateModelItemSelection(compItem, Nothing)
        Dim oCCComponentConstraint As New CCpfcComponentConstraint
        Set constraint = oCCComponentConstraint.Create(EpfcComponentConstraintType.EpfcASM_CONSTRAINT_ALIGN_OFF)
        constraint.AssemblyReference = asmSelect
        constraint.ComponentReference = compSelect
        ''constraint.Offset = 10 '' <--- CODE FAILS HERE
        Call constraints.Insert(constraints.Count, constraint)
Solution is to convert the value to a double:
constraint.Offset = CDbl(100)
