Hello All, Greetings!
We have a peculiar scenario in which a command or set of commands work in one version of Creo Parametric but does not work in the other.
Solidify does not work in a direct manner on an offset surface/quilt in Version 11.0.1.0 but works straightaway in Version 11.0.5.0 by selecting the surface and it finishes the task!...I wish to know what made this difference. Are there a few patches installed in the later version, I mean.
How can we know what is the difference between the two versions? Where can I find this information? I will appreciate if someone can please provide guidance.
Thanks a ton.
Generally speaking, the version releases are bug fixes, although there are occassionally some major enhancements that are just a little behind and don't get introduced in major releases and get added in one of the version releases.
In your specific question, this looks like it would be a bug fix.
