How can I make the features in assemblies visible... I have only the parts, not the features. I made a feature on the assembly level and I can't redefine it because it is not visible... It was a extusion in with "taking away material" and it is defined in the air (wrong direction)... so nothing is visible in the drawing and there is no feature in the tree.
Hi Steven....
Go to the Tools icon in the upper right corner of your model tree. Select Tree Filters from the drop-down menu. Make sure the checkbox for "Features" is turned on. This should fix the problem. Click the image below for detailed instructions.
Thanks!
-Brian
Hi Steven....
Thanks!
-Brian
SUper, thanks that worked for me!
