WF 5.0 Finding Erased Dimensions
Stephen
Wildfire 5.0 Drawing mode has no more show/erase icon only Show now. Erase/Unerase or deleteis the new workflow but how can you unerase or delete what you can't find? Does PTC really expect users to find this needle in a 25 sheet drawing haystack by manually looking at every views drawing tree, on every sheet, expanding every views annotation list to hopeful find a grayed out D1292
Search doesn't work !
Any Tips out there ?
Steve
Hi Steve,
You probably already have an answer but have a look in the drawing tree
under the views. You should see the erased dimensions etc. there.
Regards, Brent Drysdale
Senior Mechanical Designer
Tait Radio Communications
New Zealand
DDI +64 3 358 1093
www.taitradio.com
fklink
11-Garnet
(To:Stephen)
We decided not to use the erase anymore (which is a kind of hide).
We use the delete.
The next show will propose them for display again.
François
Stephen
(To:Stephen)
Thanks for the reply, but having20-30 sheet drawings with many view the maunal looking in the tree takes too long.
We found awork around is, to find thethe dim eg.D123in the model and convert it to AE then it can but found and unerased in the drawing.
Steve Burke
