Dear Folks
I have received a drawing from customer.
I can't understand the drawing, Please guide me.
I have attached screenshot please view it and give your valuable commens.
Regards
Viswanathan.K
Technically, this is what the drawing defines without further information. No method of attachment of the vanes. Also, dimensions b & c are assumed as 30 and 50, although it leaves a non-circular center. Post machined? Are b & c accommodation values to better represent a circular center and circumference?
If the original drawing is a DXF, you should be able to get b & c values, but looking at the drawing, and the vane thickness of the other vanes in the section, I might not trust that either.
It looks like an air diffuser plate. The outside circle is a "plate/ring" of material. The inside eight items are vanes that once cut (probably laser cut) are bent on a 30 degree angle. with the edge of the vanes still attached to the "plate/ring". I saw them a lot in the boiler industry to create a swirl in the air stream to mix air and fuel for combustion. The inside circle is a void - or absence of material.
Thanks, Dale
The drawing is certainly not complete... is it a stamping, is the vain interface to the disk welded? Essentially, the details of the transition is missing. If it is formed, then the internal tooth star washer is agood example.
The boiler company I worked for had been around since 1865, and we had drawing that were 100 plus years old. Some took training from one builder to the next to understand how to fabricate it from the 2d drawings.
Dear Antonius Dirriwachter
Could you please attach the .prt file.
We using creo element pro 5.0 version.
Regards
Viswanathan.K
I use Creo 2.0 so your version could not open the PRT file.
See the attached step file.
Thank you so much. By your 2D drawing i was so clear about the product and once again thank you so much. I saw your step file, but before that i created in my version as '.prt' file.
By using revolving option, and changing cordinates direction the vanes created and pattern to 8 segments.
Ist there any other easy way to create?
Thanks in advance.
Regards
Viswanathan.K
Like with anything PTC, there are many ways to create this. One is not better than the other.
I have creo 2.0 personaly. Could you please attach it?
Where I worked, they were laser cut and hand bent. Not pretty. Not exact, but that was boiler room tolerances not aerospace. And if I remember correct it was about 1/8-1/4" of material (depending on the size of the overall part) not cut that was holding the vane onto the ring.
If there's an overlap in the vanes, it can't be stamped. If it's plastic, you'll need a spinning core or 2, and draft gets complicated. If it's a weldment, it's ok.
It can if you stamp hard enough.
That's what purchasing agents are tought... "stamp your foot hard enough and the earth will move for you..."
Yup....and managers......
