Hi team, Good morning
I would like to know more possibilities in flatten quilt tool or some other tool to solve mty problem.
Requirement: I wanted to cut some sticker profile in 2D to stick on fuel tank (ex: Bikes). I have my tank surface (attached image) to make a flatten quilt, according to this my vendor will design the sticker and will cut the profile for me.
Attempts: But i tried flatten quilt to get the above, the thing is that am getting the flat surface with less area (50% less on vertical walls).
Solution: Please advice a better solution (images, video tutorials etc)...
2-3% less area is ok on resultant flatten surface.
Hello Rahul and welcome to the forum.
Flatten quilt is a painful tool. Nothing is intuitive and the results highly speculative. Or at least, this is my take on the process. Having said all that, I have gotten good results with nearly 180 degree wraps.
What direction ar your flatterning the quilt in? Parallel to the main plane of the part?
Maybe a screenshot of your flattening feature with all its references would help.
Thanks Antonius for your quick response on this. Please find the attached image. I am trying to do in manual
I can see how it assumes a lot of stretching.
Try creating a target plane near PNT6 tangent to the surface.
Antonius, thanks a lot for the tip...![]()
As you said in your first comment, its a painful one. I could get some more area on target plane which is tangent to PNT6. Let me know if any other tool where i can avoid the assumption on area, so that i can avoid the errors on the sticker work. I dont know how the sheetmetal people are doing the flatten to develop their blanks in a single tool or something. ![]()
