Watermarking in PV 9.1/10.0
llie
Can someone please help. I can not get the watermaking values in the .ini file to read the values from PDMLink.
Pro/E: WF5.0 M100
PDMLink: 10.0 F000
ProductView: 10.0 F000
and
Creo View 1.0 M010
Below are two different watermarking parameters that I have set in the image shwon.
Status: EPMdoc_lifeCycleState
{epmdoc_authoringApplication}
Any help is appreciated.
THank you,
Lance
llie
(To:llie)
Marc from Minnesota answered the mystery.
{ } are used for system parameters from your computer like the date and time.
< > are used to display PDMLink parameter values.
Once again thank you Marc for your assistance.
Lance
klara.lisznyai
(To:llie)
Hi Lance,
How did you export your watermark configuration?
I created a simple watermark for documents with Creo View Watermark Editor and set in Creo View. By Visualisation Guide I should now export my watermark configuration to a .zip file but I dont find wtexport command in Creo View installation directory.
My environment:
Arbortext Content Manager 10.0 M010
Creo View Professional 1.0 M010
Thank you in advance,
Klara
klara.lisznyai
(To:llie)
Hi Lance,
My environment:
Klara
Are you talking about loading the watermark files into PDMLink for the CAD Worker?
I think the documentation is not updated at that part, they still employ using ProductView.
With Creo View you can take a look at this thread: http://communities.ptc.com/message/172587#172587
