Weblink (CreoJS) Retrieve Table Help
AH_10565398
I am looking for any help on the below code.  The pin-out table is not loading in my drawing, and I'm not sure why.
The error is XToolkitGeneralError.
I currenrly have copies of  the pin-out.tbl file in my "pro tables directory", my weblinkexamples folder, and my jscript and html folders under that.  I also tried my work space as well.
The table has two repeat regions, and works fine when I load table from file in parametric.
function createEdgeNote(max /* integer */)
  if (pfcIsMozilla())
    netscape.security.PrivilegeManager.enablePrivilege("UniversalXPConnect");
  Get the current drawing & its background view
  var session = pfcGetProESession ();
  var drawing = session.CurrentModel;
  if (drawing.Type != pfcCreate ("pfcModelType").MDL_DRAWING)
    throw new Error (0, "Current model is not a drawing");
  Interactively select a Edge in a drawing view
  var noteedge = pfcCreate ("pfcSelectionOptions").Create ("edge");
  if (max != "UNLIMITED")
      noteedge.MaxNumSels = parseInt (max);
    session.CurrentWindow.SetBrowserSize (0.0);
  var selections = void null;
  try {
    selections = session.Select (noteedge, void null);
  catch (err) {
          if (pfcGetExceptionType (err) == "pfcXToolkitUserAbort" ||
        pfcGetExceptionType (err) == "pfcXToolkitPickAbove")
            return (void null);
          else
            throw err;
        if (selections.Count == 0)
          return (void null);
for (var i = 0; i < selections.Count; i ++)
  var seledge = selections.Item (i);
  var String_line1 = "LABEL: &REF_DES:ATT_CONN";
  var String_line2 = "TO ";
  var LABEL = String_line1 + "\n" + String_line2;
  var name = String(LABEL)
  Allocate a text item, and set its properties
  var text = pfcCreate ("pfcDetailText").Create (name);
  Allocate a new text line, and add the text item to it
  var texts = pfcCreate ("pfcDetailTexts");
  texts.Append (text);
  var textLine = pfcCreate ("pfcDetailTextLine").Create (texts);
  var textLines = pfcCreate ("pfcDetailTextLines");
  textLines.Append (textLine);
  Set the location of the note text
  var dwgView = seledge.SelView2D;
  var outline = dwgView.Outline;
  var textPos = outline.Item (1);
  // Force the note to be slightly beyond the view outline boundary
 textPos.Set (0, textPos.Item (0) + 0.01 + i * (textPos.Item (0) -
					    outline.Item (0).Item(0)));
 textPos.Set (1, textPos.Item (1) + 0.01 + i * (textPos.Item (1) -
					    outline.Item (0).Item(1)));
 var position = pfcCreate ("pfcFreeAttachment").Create (textPos);
 position.View = dwgView;
  Set the attachment for the note leader
 var leaderToEdge = pfcCreate ("pfcParametricAttachment").Create (seledge);
  Set the attachment structure
 var allAttachments = pfcCreate ("pfcDetailLeaders").Create ();
 allAttachments.ItemAttachment = position;
 allAttachments.Leaders = pfcCreate ("pfcAttachments");
 allAttachments.Leaders.Append (leaderToEdge);
  Allocate a note description, and set its properties
 var instrs = pfcCreate ("pfcDetailNoteInstructions").Create (textLines);
 instrs.Leader = allAttachments;
  Create / Show Pin Out Tables
try
var tableinstr = pfcCreate("pfcTableRetrieveInstructions").Create("pin-out" , position);
var dwgTable = drawing.RetrieveTable (tableinstr);
if (dwgTable != null) {
  dwgTable.Show();
} else {
} catch (err) {
  alert("Error creating pin-out table: " + pfcGetExceptionDescription (err));
  Create / Display the note
var note = drawing.CreateDetailItem (instrs);
note.Show ();
 return (selections);
2 REPLIES 2
Hi AH,
Now the standard embedded browser is Chromium, it depends on what Creo Parametric you are using, I think, this could be the problem...
Look at this thread
Hi @AH_10565398,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina
PTC Community Moderator
PTC
