I am looking for any help on the below code. The pin-out table is not loading in my drawing, and I'm not sure why.
The error is XToolkitGeneralError.
I currenrly have copies of the pin-out.tbl file in my "pro tables directory", my weblinkexamples folder, and my jscript and html folders under that. I also tried my work space as well.
The table has two repeat regions, and works fine when I load table from file in parametric.
function createEdgeNote(max /* integer */)
if (pfcIsMozilla())
netscape.security.PrivilegeManager.enablePrivilege("UniversalXPConnect");
Get the current drawing & its background view
var session = pfcGetProESession ();
var drawing = session.CurrentModel;
if (drawing.Type != pfcCreate ("pfcModelType").MDL_DRAWING)
throw new Error (0, "Current model is not a drawing");
Interactively select a Edge in a drawing view
var noteedge = pfcCreate ("pfcSelectionOptions").Create ("edge");
if (max != "UNLIMITED")
noteedge.MaxNumSels = parseInt (max);
session.CurrentWindow.SetBrowserSize (0.0);
var selections = void null;
try {
selections = session.Select (noteedge, void null);
catch (err) {
if (pfcGetExceptionType (err) == "pfcXToolkitUserAbort" ||
pfcGetExceptionType (err) == "pfcXToolkitPickAbove")
return (void null);
else
throw err;
if (selections.Count == 0)
return (void null);
for (var i = 0; i < selections.Count; i ++)
var seledge = selections.Item (i);
var String_line1 = "LABEL: &REF_DES:ATT_CONN";
var String_line2 = "TO ";
var LABEL = String_line1 + "\n" + String_line2;
var name = String(LABEL)
Allocate a text item, and set its properties
var text = pfcCreate ("pfcDetailText").Create (name);
Allocate a new text line, and add the text item to it
var texts = pfcCreate ("pfcDetailTexts");
texts.Append (text);
var textLine = pfcCreate ("pfcDetailTextLine").Create (texts);
var textLines = pfcCreate ("pfcDetailTextLines");
textLines.Append (textLine);
Set the location of the note text
var dwgView = seledge.SelView2D;
var outline = dwgView.Outline;
var textPos = outline.Item (1);
// Force the note to be slightly beyond the view outline boundary
textPos.Set (0, textPos.Item (0) + 0.01 + i * (textPos.Item (0) -
outline.Item (0).Item(0)));
textPos.Set (1, textPos.Item (1) + 0.01 + i * (textPos.Item (1) -
outline.Item (0).Item(1)));
var position = pfcCreate ("pfcFreeAttachment").Create (textPos);
position.View = dwgView;
Set the attachment for the note leader
var leaderToEdge = pfcCreate ("pfcParametricAttachment").Create (seledge);
Set the attachment structure
var allAttachments = pfcCreate ("pfcDetailLeaders").Create ();
allAttachments.ItemAttachment = position;
allAttachments.Leaders = pfcCreate ("pfcAttachments");
allAttachments.Leaders.Append (leaderToEdge);
Allocate a note description, and set its properties
var instrs = pfcCreate ("pfcDetailNoteInstructions").Create (textLines);
instrs.Leader = allAttachments;
Create / Show Pin Out Tables
try
var tableinstr = pfcCreate("pfcTableRetrieveInstructions").Create("pin-out" , position);
var dwgTable = drawing.RetrieveTable (tableinstr);
if (dwgTable != null) {
dwgTable.Show();
} else {
} catch (err) {
alert("Error creating pin-out table: " + pfcGetExceptionDescription (err));
Create / Display the note
var note = drawing.CreateDetailItem (instrs);
note.Show ();
return (selections);
Hi AH,
Now the standard embedded browser is Chromium, it depends on what Creo Parametric you are using, I think, this could be the problem...
Look at this thread
Hi @AH_10565398,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
