What determines 'zoom' of object when view default
msteffke
What determines size of object in screen when you 'view default', or hit
that little magnifiying glass tool button? I want to use
ProRasterFileWrite to dump a tiff of a shaded model. However the model
is always zoomed out too far. And is there a way to zoom the assembly
in closer prior to the rasterwrite?
Thanks for any idea,
Mark Steffke
2 REPLIES 2
You need to use ProViewMatrixSet() to set the zoom of the current view. You can specify a zoom value in the new matrix that you use. Read the API Wizard under User's Guide->Graphics and Object Display->Solid Orientation and additionally User's Guide->Coordinate Systems and Transformations->Coordinate System Transformations. The latter will explain the contents of a matrix.
Patrick Williams | Engineering Systems | Sr. Applications Engineer | Steelcase Inc. | 616.698.4078
[cid:image003.jpg@01CA78BD.E2AD4A00]
msteffke
(To:msteffke)
Thanks Patrick, I'll mess with this a but and see how I like it.
Mark Steffke
