What file formats can CREO products export into?
ptc-4612898
I am new to the CREO product suite and am scouring for as much information as I can to achieve the goal of knowning what file formats CREO can export/save files into?
From what I have found researching so far, creo has a number of applications:
Creo Sketch
Creo Layout
Creo Schematics
Creo Parametric
Creo Direct
Creo Options Modeler
Creo Simulate
Creo Illustrate
is there a comprehensive list available that outlines what file formats each can export/save to?
This information is much appreciated so I can understand what flexibilties I can work with when using the Creo product suite.
Very much obliged with your insight, have a great day.
Hi Bruce,
Platform Support for Data Exchange (CREO 2.0) you can find here: creo2_hw_notes.pdf
Vladimir
Best Regards,
Vladimir Palffy
Vladimir,
Thank you for this wonderful document!
Hi Bruce,
You Are Welcome
Vladimir
Best Regards,
Vladimir Palffy
Vladimir,
concerning the file formats listed.
Are these meant to show what file formats CREO can accept or also what file formats CREO can produce?
For example in the case of ACS to CATIA:
If INPUT = *.acs
Then OUTPUT can = *.model
