"Wesley Gegg" wrote:
1. All, to create a composit curve. Select the edges, copy and paste. This will then bring up the dash board with all of the options. The same process to copy surfaces. The sweep problem is just the way you are selecting your edges, I assume that you are using the control key. Check out the selection area of the Quick Ref. Card. Hope this help, as I am making some assumtions. Wes
