Wildfire 3.0 on Win XP64 toolbar problem
ShaunRobertson
I have an installation of Wildfire 3.0 m180 on a windows XP64 box which has a strange issue. If I open an assembly or whatever from the menu then it opens OK, but if I try to use the toolbar buttons to Open a drawing or create a New drawing Pro-E freezes. When the Assembly drawing is opened using the menu's and the cursor is moved over the model then multiple datum planes are shown, so many that the assembly is hidden by them. I do not know if the 2 problems are linked or not, but any advice would be welcome. The 32 bit version of the same cut works fine without any of the above issues.
0 REPLIES 0
