Wildfire 4 and PDF Creation Issues
ptc-3121080
All of our production drawings are dual dimensioned with inches as primary, millimeters as secondary and located below primary. This week we upgraded from WF3 to WF4. Now when I create a PDF of a drawing the secondary dimension places the tolerance first and than nominal specification as one single unit. Example: Should be [0.622±.038] what is shown [±0.0380.622] I have determined that selecting "stroke all fonts" will correct the issue however this action can only be used once because of the next attempt will fail due to a memory error requiring a restart of WF4 and file sizes increase significantly. Example: File Size without stroke all fonts 101 KB File Size with stroke all fonts 2.54 MB Any idea's on how to fix? Thanks.............S. Springer
2 REPLIES 2
JerseyC
6-Contributor
(To:ptc-3121080)
We have same problem with sizes of PDFs in WF5_M020.
Okay, found a couple of work arounds that will allow for dual dimensioning and keep the file size down by simply saving as a PDF without stroking of fonts. >The first one was remove the brackets from secondary dimensions. This could create some confusion without any true seperation of primary[secondary] so we have elected not to follow this route. >The second, change our tolerancing practice away from symetrical to a plus/minus format. It works and this is what we've decided to do. Hope this helps..........
