Wire harness drawings?
TractorGuy
I was just wondering if anyone out there is currently making wiring harness drawings without using Pro/Cabling? I work in a small engineering group and we don't have access to Pro/Cabling at the moment, but we have a need to make a few simple harness drawings. Right now we are either importing DXF data from previous harness drawings or creating everything from scratch with the sketcher in Creo 2 (very frustrating). Basically, I'm trying to figure out if there is any easier way to do it the hard way?
1 REPLY 1
You've posted this question in the Creo Elements/Direct group, you should post it in the Creo Parametric group.
Wim
