With the search tool I would like to select all the components which have for designation_1 = "hinge
MG_9638468
With the search tool I would like to select all the components which have for designation_1 = "CAISSON"
But I can't find the category ...
to find parts/subassemblies containing specific model parameter (not component parameter), use following search "command".
Martin Hanák
8 REPLIES 8
Look for Part>Expression. I'm not sure why it's called "expression" in the Search Tool when it's called parameter everywhere else.
that's what I'm looking for! on the other hand I can only find the parts with this solution I cannot find the assemblies ?
tbraxton
(To:MG_9638468)
Look for components instead of parts. This should get parts and assemblies that are present in the top level assembly that you are searching within.
Involute Development, LLC
Consulting Engineers
tbraxton
(To:tbraxton)
I tested this in Creo 7 using look for components in an assembly but that only returned .asm models. This was not as I expected, if anyone can explain why I, am interested to know.
In order to get the desired results I built a search query that looks for components and parts.
Look for partsLook for partsLook for componentsLook for components
Martin Hanák
It's exactly that !
thank you so much
Thank you for sharing this Martin. It is so powerful!
SYNDAKIT
(To:MartinHanak)
Martin you are THE MAN!
