With the search tool I would like to select all the components which have for designation_1 = "hinge
  • September 10, 2021
  • 2 replies
  • 5490 views
With the search tool I would like to select all the components which have for designation_1 = "CAISSON"
But I can't find the category ...
Best answer by MartinHanak
to find parts/subassemblies containing specific model parameter (not component parameter), use following search "command".
Look for Part>Expression. I'm not sure why it's called "expression" in the Search Tool when it's called parameter everywhere else.
that's what I'm looking for! on the other hand I can only find the parts with this solution I cannot find the assemblies ?
tbraxton
Look for components instead of parts. This should get parts and assemblies that are present in the top level assembly that you are searching within.
It's exactly that !
thank you so much
