Hello, I'm new to Pro-E,I'm using Wildfire 4.0. My problem is that whenever I create a dimension with a tolerance with a +0 value or -0 value the 0 does not appear with the rest of the dimension. For example 1.75+.000/-.002 only shows up at 1.75-.002 How can I get the zero values to show up on the drawing? Thanks.[/img]
