a folded metal sheet should be bent again
mawi-1848
2-Explorer
I use Creo Parametric 9.0 / folded metal sheet should be bent again
I have to construct a folded sheet metal strip with a 90° bend. The folding (180° tab) of the sheet is no problem, but the bending of the folded sheet.  Are there any ideas?
kdirth
(To:mawi-1848)
Create the 90° bend first.
Next create a 180° / 0R flange for each edge. (Hold shift to chain select the edge.)
This should unfold completely.
5 REPLIES 5
StephenW
(To:mawi-1848)
Can you include a picture of what you are wanting to do?
kdirth
(To:mawi-1848)
Something like this:
The hem has to be created after the bend.  Sheetmetal will not create a bend through a hem.
mawi-1848
2-Explorer
(To:kdirth)
Thanks for the quick reply.
Yes, something like your picture and something like this:
Now I have constructed the hem (fold) as a profile and then bent it.
But I can't completely unwind the sheet metal construction this way.
kdirth
(To:mawi-1848)
mawi-1848
2-Explorer
(To:kdirth)
Many thanks, it worked!
