adding a new wire parameter
amedina
I get this:
?msg_err@>>>> error <<<<
?msg_err@Field assignment not defined for type UNSET
when I try to apply a data set to a wire
I added an RSD global parameter called "desc" for some description we use
already in pro diagram and on a pro/e report table.
This description has spaces and such. I want to add this description to my
wires. But when I apply the data set I get that error. I can update or
create a new dataset, I can select a data set but I cannot apply it to a
wire (or connector or anything else for that matter).
Any ideas? The dataset is filled in for "desc"
here is a sample csv:
type,datatable,,,,,,,,,
$$index$$,spool_name,color,min_bend_radius,thickness,obj_type,units,wire_gauge,stupid,name_format,$$datasettype$$
1,102858-003,GRN/YEL,2.057,4.115,WIRE,MM,6,some_description_2,W###,SPOOL!WIRE_SPOOL
2,116123-004,GRN/YEL,1.254,2.588,WIRE,MM,10,some_description_3,W###,SPOOL!WIRE_SPOOL
3,116123-011,GRN/YEL,0.6455,1.291,WIRE,MM,16,some_description_4,W###,SPOOL!WIRE_SPOOL
4,101986-000,WHT,0.2555,0.511,WIRE,MM,24,some_description_5,W###,SPOOL!WIRE_SPOOL
5,101986-003,RED,0.2555,0.511,WIRE,MM,24,some_description_6,W###,SPOOL!WIRE_SPOOL
6,101986-008,PRP,0.2555,0.511,WIRE,MM,24,some_description_7,W###,SPOOL!WIRE_SPOOL
7,101986-009,GRY,0.2555,0.511,WIRE,MM,24,some_description_8,W###,SPOOL!WIRE_SPOOL
Can someone shed some light on this one???
0 REPLIES 0
