adding different materials to parts of a model
MU_10243770
2-Explorer
I want to add Copper material to the cylinder and aluminium for the box below. But when I do, the same material gets applied to the entire object.
please help!!!
please help!!!
I think the requested functionality is available starting from Creo 7.0. You can create two bodies and assign different material to each body.
Martin Hanák
2 REPLIES 2
please help!!!
Martin Hanák
BenLoosli
(To:MU_10243770)
You will need to model it as 2 separate bodies in your part file as Martin shows. This can only be done in Creo 7 or newer.
If on an older version of Creo, you will need to model them as 2 separate part files and then assembly them together in an assembly file.
