adding jogs to mbd leader annotations
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Hey guys,
I hope there is a better answer than "not possible" (using creo 4.0)
My company is new to MBD, I am detailing a very large complex weldment. I am creating the tabs, comb-states, sections, details etc. but one thing I have noticed that is driving me nuts is I cannot add a jog to the leader lines. For the weld callouts, annotations or the notes. This only applies in the 3d space. I know how to add jogs and breaks in 2d space. But cannot seem to find a work around that is quick enough to justify the effort. The image attached is just one example of why I want a jog, so I am not dragging the leader across the entire feature.
- Labels:
Assembly Design
General
Weld Design
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I asked the same question yesterday. Hope someone has a solution, though it seems Creo can't do it.
Article - CS409963 - How to create JOG for Symbol and Leader Note in MBD Creo Parametric
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Creo-7. Right click on annotation and play:
Looks like we don't have much to work with in this event. Hope PTC has addressed this in developing MBD releases - it would be SOOOO nice! No doubt you already did all this but just-in-case I give this to you.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I've got Creo 10 and I've got the same options you have. You can play with the jog that's already in the note, but nothing beyond that. In weld annotations you can't do anything
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Thank you for the guidance. It seems it's such a glaring obvious fix that PTC overlooked it.
Instead of spin my tires and hope for a solution I have decided to just add more rep states and just place my weld callouts on different comb state tabs so it looks cleaner. It's just a lot more work with naming everything trying to comply with MBD standards.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
@BR_11844479 wrote:It seems it's such a glaring obvious fix that PTC overlooked it.
Yeah well that's just Creo in a nutshell to be honest....
So yeah, like with everything PTC, use a workaround and lose all "intelligence" in your model😂 (In this instance, manually place the weld callouts)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
No jogs available in Creo 12.0.0.1 when I tried in Creo+
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I put a request into moderator to (also) escalate this issue to PTC Committee in hopes that it's a simple add-on or reason why it cannot be. I will try to bring it to other PTC resourced sites and maybe anyone else can do the same. Something we all think is beneficial in the ever-evolving MBD world. Thanks!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
The appropriate place to put "enhancement requests" is the Ideas area:
https://community.ptc.com/t5/Creo-Parametric-Ideas/idb-p/creoparametric
Moderators can sometimes help, but ideally you would create an Idea, appropriately documented.
