asm with parts in different folders?
DarylWolf
Is there a way to have parts in different files and still have an assembly not crash. I have three parts I will be working on and want to be able to periodically check the comparisons as I go. I dont need anything too complex. Its just for visual comparison. Im not crossing info from one to another or anything.
This info may be on here already but I couldnt find anything.
3 REPLIES 3
Hello Daryl
If you need read parts for assembly from many folders you can create your own file (*.pro) which contains the path to the directories
For example:
D:\PURCHASE_PARTS\nuts
D:\PURCHASE_PARTS\screws
D:\PURCHASE_PARTS\pins
D:\PURCHASE_PARTS\washers
When you have your own search_file.pro (your search path file) do you need set this file to config.pro with configuration options:
search_path_file ...path...\search_file.pro
Have a nice day.
Vladimir
Best Regards,
Vladimir Palffy
thank you , Vladimir. it is useful for me. you have a good heart.
Thank you too Andy. It is my pleasure.
Vladimir
Best Regards,
Vladimir Palffy
