balls
ptc-3254744
balls
hello everybody, i want to know that, in the assembly part,what will be the inter-connection between the balls of the ball bearing so that they will not show the interference between each other...and how to restrict the motion of one ball in respect of the other one.
6 REPLIES 6
manoj, when i assembled a ball bearing i constrained the ball to the race through its plane. regarding the interference i just patterned the ball via the center using PCD to prevent interference. hope that helps. Hey do you happen to work for a bearing manufacturing company in India? if so, whats the name of your company? johnleo
I thought this was going to be a rude post
"Grahame Ward" wrote:
I thought this was going to be a rude post 🙂
WillyC
(To:CM10)
The worst thing about censorship on the Internet is [REDACTED]
CM10
(To:WillyC)
