I can't figure out a way to do this in Pro:
I have a thick radiused rectangular plate that gets it's edge milled all the way around it's perimiter and some material removed from the interior - but not thru. Then the entire part is pressed into an arc with a specified R. I need to show the part in both PLAN and FORMED views on the drawing. I cant' bend a SOLID (except in WARP - in which I can't specify a Radius), and I can't cut one side of a SHEETMETAL part. Any ideas? Thanks in advance.
