bending milled plate
jbrouch
7-Bedrock
I can't figure out a way to do this in Pro:
I have a thick radiused rectangular plate that gets it's edge milled all the way around it's perimiter and some material removed from the interior - but not thru. Then the entire part is pressed into an arc with a specified R. I need to show the part in both PLAN and FORMED views on the drawing. I cant' bend a SOLID (except in WARP - in which I can't specify a Radius), and I can't cut one side of a SHEETMETAL part. Any ideas? Thanks in advance.
1 REPLY 1
Try Spinal bend or toroidal bend.
Pro/E forum on Mcadcentral.com has good info on toroidal bend and there
is a good tutorial on spinal bend over at e-cognition.net
Thank you, Jim Flores
Mech. designer/CAD admin.
Clinical Care Systems
Philips Healthcare
2271 Cosmos Court
Carlsbad, CA. 92011
