i am new for creo, previously i am work in catia V5, in catia we can create any number of general view for different parts, but i can't create general view for different parts in pro-E. is it possible in creo.
To add to that, yes, you can have multiple models in drawings.
You activate the model you wish the next view to show.
This is done in the tree header dialog on the bottom tree (model tree).
Be careful as each model will have its own unique scale setting.
Prabaharan,
You can add multiple models to drawing and create views.
In drawing add models using Layout > Drawing Models > Add Model > Add required model > Done/return. Insert a general view for model.
Prabaharan,
Does any of the reply in this post answer your query?
I have only pro-E wildfire V4 is it possible in it...
It is possible in Wildfire 4.0, menus are as:
1. File > Properties > Drawing models > Add models > Select required model > Open > Done/Return
