Community Tip - You can subscribe to a forum, label or individual post and receive email notifications when someone posts a new topic or reply. Learn more!
X
I'm in WF3, m160. I have a sheetmetal part created using File > Mirror Part > Include all feature Data >, so my part has a full model tree. However, at the bottom of the model tree is the Mirrored Merge feature. The issue is I cannot flatten this part. I can delete the features that were in the source part, but which I don't need here. However, I cannot flatten it. Can't unbend, can't use Flatten tool. Nothing. Any ideas for how to get this to work without re-modeling the part?
Thanks.
Lyle Beidler MGS Inc 178 Muddy Creek Church Rd Denver PA 17517 717-336-7528 Fax 717-336-0514 <">mailto:-> - <">http://www.mgsincorporated.com> This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
Then there must be some feature that is not playing nicely with the mirror. I just tested this in WF4. Parts attached. It worked fine. I don't have wf3 loaded to test.
Thanks to Ron. His comment "Then there must be some feature that is not playing nicely with the mirror." Got me thinking. The original part had an unbend/add a cut/bend back sequence. Once I deleted that from the original before mirroring, the new part unbends just fine.
