can't open protab piping_mcat_dir.ptd
kachten
hello everyone,
I trying to change a spec database for piping.
My Pro/Table does not load or work. Anybody has a solution herefore?
Greetings, Koen
JimBarrettSmith
(To:kachten)
hmm thats strange. Can you execute protab.bat from the bin dir under the load point with a double click?
12 REPLIES 12
JimBarrettSmith
(To:kachten)
From a command prompt you should use just protab
This will launch protable
I tried but it doesn't work. Same story :-).
Any suggestions? 🙂
JimBarrettSmith
(To:kachten)
yeah that works. Protable opens 🙂
But I thought you have to open pro/table from within Creo parametric??
Please view the error and provide me an a solution.
Thanks & Regards
Viswanathan.K
JimBarrettSmith
(To:kachten)
I just have a protab shortcut on my desktop
hello,
does that shortcut works good for settting up piping specs. I found in the ptc training of Piping the following quote:
"The Pro/TABLE editor is used to edit all specification-driven files. This editor must ALWAYS be started from within a Creo Parametric system window to ensure correct formatting of table cells."
gr. Koen
JimBarrettSmith
(To:kachten)
Its always worked for me. You can also use something like word pad and text pad
thankyou very much for your help :-).
gr. Koen
when I want to open a file, protab crashes....
JimBarrettSmith
(To:kachten)
Sorry to hear that. I would suggest you contact technical support and ask them to investigate your problem via a webshare.
As a workaround use wordpad or Text pad
hellow,
i contacted tech support.
The solution is that you have to add the installation bin folder of creo parametric to your environment variable 'path'
System properties -> advanced tab -> click "environment variables" -> go to Path -> add your bin folder of creo parametric to it (e.g. C:\PTC\Creo 2.0\Parametric\bin)
restart creo Parametric -> it works
