cannot delete parameter
DaveClark
2-Explorer
Hello Everyone,
I've got some parts from a vendor and they have parameters attached that we need to delete. We can delete most of them, but there are two remaining. Neither one has a value set, just a name. The parameters are not locked or designated.
Has anyone seen this before?
Thanks!
Dave Clark
CAD Application Engineer
Dukane Corporation
Intelligent Assembly Solutions Division
2900 Dukane Drive
St. Charles, IL 60174
630-797-4922 (Phone)
630-797-4949 (Fax)
[cid:image001.png@01CD7165.2D810C40][cid:image003.png@01CD7165.2D810C40]<http: twitter.com=" dukaneias=">[cid:image004.png@01CD7165.2D810C40]<http: www.youtube.com=" user=" dukaneultrasonics=">">http://usblog.dukane.com[cid:image002.png@01CD7165.2D810C40]<http: www.facebook.com=" pages=" dukane-intelligent-assembly-solutions=" 3139592...
[cid:image005.jpg@01CD7165.2D810C40]
14 REPLIES 14
Sorry, I should have added there aren't any relations either.
BenLoosli
(To:DaveClark)
What version of Pro/E are you using?
What are the parameter names?
Try setting this config.pro option
new_parameter_ui no
Thank you,
Ben H. Loosli
USEC, INC.
I'd like to thank everyone for their help. Unfortunately, nothing seems to be working. If we figure it out, I'll surely post the answer.
Here's a little more info from the message window when I try to delete, and then use "Show\Where Used" on the form:
[1]Parameter PT cannot be deleted.
[1]Pick global parameter, or select NAME to type in a name.
[1]Type global name: PT
[1]Global PT not available to this model.
Try creating a new part and use the vendor part as the start part
instead of your normal start part. Maybe that will break whatever is
locking the parameter.
Or, create a new part from your start part and then copy all the
features from the vendor part (highlight everything but the 3 def.
datums) and paste special, advanced reference configuration into your
new part. That should bring all the features over but (hopefully) not
the parameters.
In both cases you'll have to replace the part in any assemblies, and I'm
assuming the vendor part is a native Pro/E part.
Doug Schaefer
LinkedIn
Doug,
The start part didn't work, but the cut and paste did. We just need to decide how to move ahead with this since we have 1000+ of these to go through. Our poor intern will lose his mind! There isn't an easy automated way to do this, is there?
-Dave
Glad it worked, but bummer on having to do it 1000+ times. I can't
think of a way to automate it, maybe someone else can.
Doug Schaefer
LinkedIn
AndyHermanson
(To:DaveClark)
Would a Batch ModelCHECK be able to do this if you are using Windchill?
Andy Hermanson
Engineering Design Applications
tel 605.275.1040 x51114 mobile 605.310.8168
website www.daktronics.com
Here are a couple of crud but sometimes very effective ways:
1. Trail Maker (v2) originally developed by Edwin Muirhead. I have a link
below to a portion of my OLD web site. I don't maintain it any longer but
it may work. It has helped me on a few occasions, thus I keep the old link
live.
before launching pro/e
add ALLOW_CREATE_PDM_PARAMYes to your config.pro
This should allow you to edit and remove locked parameters.
This is a hidden config option
Hope this helps,
Don Anderson
Does anyone know how to create a family table part such that each instance is a different color for Wildfire 4.0
I tried various techniques but haven't found anything to work yet. The part will be part of a standard library file.
What paramater could you add that would like to each color unique to that instance.
Evan Coffield
Has anyone find how to best translate files prt,assy, and drawings with features from UG 6 -- WF 4.0 with correct layers, parameters, and dimensions.
EVan Coffield
One way that works is to create a surface copy and color the quilt. Select a surface, RMB select solid surfaces, then do the control-C, control-V to copy and paste the copied surface as many times for as many colors as you need. Then color the surfaces, add them to the family table and turn them on or off as appropriate...Thanks… Pa
BenLoosli
(To:DaveClark)
A couple of companies come to mind.
