changing mass and units
gbon
Hi alls,
I have difficulties managing mass properties of an assembly.
One sub-assembly has wrong units and its weight is very very big.
It's made of thousand parts.
So, is it possible to simply disable its weight inside whole assembly?
gkbeer
(To:gbon)
As long as all the parts have been assigned densities consistent with their units, all should be fine.
When showing mass props in the model tree, sub assemblies having odd units will show their mass in their units.However Pro will sum the masses correctly in the top assembly.
As long as every part has the correct density applied w/respect to its units, & the mass props have been calculated, the top assy and all subassemblies will show the correct mass.
Example:
Assy1 , lbs, 11.023
Sub assy grams. 5000
Part a. Grams. 1000
4x Part b, pounds 2.2046
The best way to audit the models is to add the columns pro_mp_mass & pro_mp_density to the model tree, then scan down the list. Parts with a density of 1.000, or that show more or fewer decimal places than are reasonable, should be checked/repaired.
This stupid forum is deleting all the cr's.
Ok that's fixed, the original post was from my iPad, I had to edit the post from my pc.
