circular centerlines - bolt circle
nrollins
How can I get a circular centerline on a bolt circle?
The drawing option:
radial_pattern_axis_circle
only works for a dimensionally based pattern. If the pattern is axially
based, the option does not work.
Doesn't "Axis Pattern" imply an annular centerline could exist?
Do I have to resort to a sketched entity?
Thanks.
-Nate
2 REPLIES 2
Nate,
What version are you using?
We had issues early on (WF2?) with the axis pattern, in some cases
finding that the only way to make it give a proper pitch circle was to
create it as a dimension pattern, complete with plane-on-the-fly, then
convert it if you really wanted.
More recently (now on WF4 M160) it seems to be doing a more reliable
job, although it's still not 100%.
I agree - why would you create an axis pattern and want to have
non-radial crosshairs for each feature?
Jonathan
nrollins
(To:nrollins)
Yes, I am on WF2 for this inquiry. Apparently, WF5 does a "better" job at
this, but it is a limitation up until that version.
My flanges all have a sketch at the end of the tree to show a BC, formatted
to look like a CL in the drawing.
Could be worse.
Thanks to all.
