color wire cabling creo parametric
ptc-5016188
hello,
can someone help me? I'm learning module cabling alone, now I have a problem, when I create the spoos, imposed of different colors, but when I stretch the wires, the color is always the same, never changes. how do I fix this?
3 REPLIES 3
Most features in Creo has a default color... a part color, if you will. You have to assign colors to the surfaces manually if you want different colors within the same part. Even with this, there are limitations.
I do not have the cabling module, but I suspect it works the same way.
The module Cabling is in all versions, applications, after creating an assembly.
It's not like the normal models the choice of colors, you must set when you create the spool.
I think there is a bug in the softwere if anyone knows how to solve please it is very important
You had me going there for a second...
Option CABLING not ordered, please contact your sales representative.
Please check "File->Options->Licensing" or Visit http://www.ptc.com/support/apps/sw_trial to try out options
...means that I don't have it.
