component adding
dgrobe
component adding
So, still learning how to create wire harnesses.
i am having trouble getting the harness to add components.  when i start the harness, add wire, select the start point, as entry port, it gives me the option to set the parent as a component.  however, whenever i select the end point, it doesnt give me the option to set parent as a component.
so, my wire going to that CSYS, doesnt follow the Z, it just goes directly to that CSYS.  however, the first point does follow the Z, and i can modify how far it comes out.
0 REPLIES 0
