controlling representation in family table
MB_10357724
Is there way to control the representation in the family table? or Any way to control the subassembly in the top level assembly ? refer the attached image
i want to swap the instance of 020008946_Generic at top level MB000A014 thru top level family table. pls suggest.
Suggest an alternate way if the above listed options don't exists in Creo.
You can do this by creating family tables at each sub assembly level.
000-CD0 level  you have an instance that calls out the 020008946 instance
000-BIC you have an instance that calls out the 000-CD0 instance
Top level you have an instance that calls out the 000-BIC instance
If you haven't do this before at each subassembly level, you add the component to the family table and then you paste in the name of the instance that you want in the family table. See video here: https://youtu.be/m5cXl89oxhk?t=117
Alternatively depending on your MRP rules you could just make a Simp Rep at the top level that hides the 020008946 component and then assemble in the instance that you want over the top of it at the top level. This is likely going to cause other issues for you though and in general is considered bad practice.
This Creo Parametric tutorial shows how to create a Family Table at the assembly level in which components and assembly-level features are included or not. It shows how to select the instances of a part-level Family Table as well as how to use the Replace command in a higher-level assembly. For ...
