I know that that the circular reference files (.crc) file will be automatically saved in current working directory. But if i'm online, connected to windchill, where these files will get saved?? Is there any configuration parameter that controls this path location?
Thanks!!
.crc files and all the other information files save to the start in directory. You can find that if you RMB Properties on the icon used to start creo and look at the "start in" folder.
