creo 2 mm into inches.
ptc-5376535
Hi ,
I have a model and it is in mmNs units . I want to change into inches without failing of any feature .
How can it be done?
In Creo, you change the model properties. You are give the option to convert the units 1:1 or by default, 25.4:1.
Menu: File>Prepare>Model Properties>Units (change) and highlight > Inch lbm Seconds and click > Set.
...and welcome to the forum.
