User interface file for Creo 1.0 that makes an attempt to memic WF4 pull downs.
There are some icons missing. Usually means I couldn't find a suitable replacement in Creo.
Updated file 2/1/12
Added Assembly Mode UI
Made Model, Assembly, and Drawing modes look alike.
Updated file 2/21/12
Corrected Edit->Offset
Thanks! I'm going to have to try it out.
If you find that in Assembly mode the ribbon is blank...
RMB --> Customize the Ribbon
and place a check in all the groups shown.
Then save the configuration
