creo and Internet explorer not compatible
LF_904884
I am using Creo Parametric 3.0 M110
Unable to access Windchill server within the Creo embedded browser using the Internet Explorer
Doing only a cursory investigation (by attempting to go to common sites like mcmaster.com) it appears the "browser" in Creo is limited in its capabilities. I think it's main intent is to be used by Creo to provide information from PTC, so maybe it's a restricted feature "browser", not intended to be used for general browsing. They likely use it because it's almost guaranteed to be present on every system running Creo, since it only runs on Windows operating systems.
You'll just have to use an "actual" browser to work with Windchill and such.
